idle issues
Discussion in 'The Garage' started by Big GMC truck, Mar 31, 2006.
  1. Big GMC truck
    Big GMC truck Registered Member
    Aug 23, 2005
    73
    California
    Should my truck's, 1984 GMC K1500 305, idle be the same in park and in gear? Currently, the idle is 600 rpm in gear and increases to 1000 rpm when placed in park:confused: . My mechanic says the accelerator cable is the cause of this? Is this true or is there something else causing the problem? Thanks
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    sorry, but your "mechanic" doesnt know his ass from a hole in the ground. it is normal for an RPM drop when the trans is placed in gear, and it fluctuates with timing adjustment. check your ignition timing, and adjust your idle screw on the side of the carb. should be like 850 at idle, 750 in gear.
