Idle Mixture Adjustment ASAP
Discussion in 'The Garage' started by Hossbaby50, Sep 12, 2004.
  1. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Which way do you need to turn the idle mixture screws to lean a carb out? I think it is inward correct.
    I need to lean out the idle mixture on my 2bbl (holley knockoff I think) carb on my Jeep. It is a '73 with 304 V8. I adjust both idle screw in to lean the carb out some correct? Thanks
    Harley
    P.S. I am doing this and some other work right now so the sooner the answer the better. Thanks
  2. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Yeah Harley, IN to reduce fuel (Lean)
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    only affects idle though
    as soon as the throttle plates open a fraction it no longer feeds from the transfer slots
