idle prob.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OKIEnVA, Aug 28, 2006.
  1. OKIEnVA
    OKIEnVA Registered Member
    Jan 16, 2006
    32
    Northern virginia
    hey guys i got a 91 k5 350 tbi. this prob been goin on for yrs but getting worse here lately. after running it kinda hard or playing wit the throttle it will start to idle real low like shes strugglin to stay running, if i pop it in nerutral rev it up for a lil bit, then wham it magically clears up and goes back to running good. any ideas or things i could check.?
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    A bad throttle body base gasket will cause idle problems. Pretty common for them to go out. Also check all your Vaccum lines for cracks/breaks
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Yeah, ditto what Thunder says. Are you getting any codes? When was your O2 sensor last changed? Done any mods to the motor? Cleaned your throttle body lately? Running an injector cleaner through may well help with that.
  4. OKIEnVA
    Jan 16, 2006
    32
    Northern virginia
    motors stock, ive ran some tranny fluid threw the throttle bosy put some cleaner in the fuel tank, i was gettin a chk eng light, but i was tired of looking at it over the yrs so i took the bulb out of the cluster. ill bring it in the shop tomarrow and see what i can find. o2 sensor never been replaced. i got 152 thousand on her. when shes not idling like crap shes strong. and pretty smooth, the part that confuses me is it will last for a couple seconds, then clear right up. like nothing was ever wrong.
  5. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    Put your bulb in and check the codes!
  6. loafer
    loafer 1/2 ton status
    Aug 19, 2003
    634
    Lyman, Maine
    Usually a bad TB gasket will cause a high idle because it creates a vacuum leak. Still worth checking though.
    When you decelerate and come to a stop does it stumple and/or idle too low? If so it may be a leaky/bad EGR valve.
