idle problem..
Discussion in 'The Garage' started by bryguy00b, Dec 13, 2002.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    my blazer runs at a high rpm like i got my foot right in it when its sitting in park/neutral..but when i put it in gear it will back down..any one got a clue?
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    maybe because when you put it in a drive gear you put a load on the motor, so it idles lower. /forums/images/graemlins/smirk.gif just a thought.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. Geno
    Geno Registered Member
    Nov 18, 2002
    52
    Dorchester, Nebraska.
    Sounds like maybe the choke needs adjusted, might be stuck on fast idle, Spray alot of carb cleaner on it , might be gummed up. Check idle screw see if you can adjust it down a bit. Check your timing, should be set around 8 or so , (with vaccum disconnected.) Just some ideas, hope it helps /forums/images/graemlins/wink.gif
  4. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    yea something i nosticed the choke light comes on and seems to stay on...i dunno..i had it running for a few minuts just to run it for a little bit...i had to stop cuase it has a major exhuast leak and i was dying from the smoke (and have my floor is ripped out..so it was going in the cab) lol...but my dad says when he lets it run longer and it warms up it goes down...so maybe i just didnt run enough to see...it HAS been in the cold garage for like a month now with out running... /forums/images/graemlins/smirk.gif
