idle problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by unick, Dec 17, 2003.
  1. unick
    unick 1/2 ton status
    Aug 16, 2003
    4,286
    San Diego Comufornia
    Sometimes when Im idleing my truck dies. B4 it does it usually kindof sounds like its gonna die but then revs back up where it should b. It kind of goes put put and then dies unless I give it some gas. Is there anyway I can ix this? O yea its an 87 K5.
    thanx
    Nick
  2. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Mines not dieing, but it bogs down then comes back up, bogs down and comes back up. /forums/images/graemlins/thinking.gif
  3. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Are they carburated? Could it be the choke kicking in?
    -Andrew /forums/images/graemlins/usaflag.gif
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check for vacuum leaks first. But hooking up a scanner and looking at the data coming from the TPS would show you if the TPS is flaky. If the signal from the TPS is jumping around, then the ECM gets confused and can't keep the engine running at idle.
  5. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Mine did that just before the fuel pump went. /forums/images/graemlins/mad.gif
  6. unick
    Aug 16, 2003
    4,286
    thats what mine does it bogs down and if i dont push the gas pedal it will die. Its not that big a deal cause I can keep it from dieing but its kind of annoying when it does.
    Nick
