Idle problems
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Greek, Dec 21, 2005.
  1. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    My truck has a weird idle while it park. It will run fine when its started but when it gets warm it starts to surge. I've replaced fuel filter, egr, o2 sensor, wires, plugs, and cap. Do you think a rusted distributor could be the problem or maybe like a IAC or something? need help
  2. btolenti
    btolenti 1/2 ton status
    Sep 28, 2003
    644
    Gilroy, CA
    I have heard a bad coolant temperature sensor will cause this. Cheap part to replace too, should only be 10-15 bucks.
  3. erik59
    erik59 Registered Member
    Jun 4, 2005
    52
    Parkersburg, WV
    Mine did the same thing until I found out I had vacuum line off of the TBI base.
    Erik
  4. K5Greek
    Nov 25, 2005
    2,054
    Vineland, NJ
    Yea i checked for that too and there are no leaks. For the coolant sensor im going to be replacing the radiator cause it cracked and im throwing in a new sensor so ill see if that helps any
  5. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Check the TBI base gasket too. Pretty common for them to leak and cause idle problems.
