Idle speed question
Discussion in '1982-Present GM Diesel' started by Can Can, Nov 13, 2002.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Over the course of a couple of years my idle speed screw works it's way out a bit. As a result I have turn it in a bit to bump the idle back up.
    I usually adjust it so the idle "feels" right, and I'm pretty sure curb idle is 600 RPMs(or is it 700? Whatever- it's in my book), but how exactly do you set your idle speed to spec with no wires to connect a timing gun to?
    I'm sure someone here can tell me how. I'm not worried that I'm running the sucker too high or low, but it would nice to know how close I've been in the past.
  2. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    You can get a diesel tach that uses a transducer that clips onto an injection line and senses the injection pulses, this signal is sent to a device that converts the pulses into RPM on a readout. I believe that you can run a timing light off of some of these as well. Im sure they are not cheap though, so really not worth buying.
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I was looking into that and they are not cheap but not that expensive, I think the cheapest setup for a diesel tach was around 200 complete.
  4. BlueBlazer
    Feb 15, 2001
    1,940
    That might be for a tach like you leave in the vehicle permanantly, with a needle and all like a gas tach, I was talking about a digital portable one, I think its a bit more accurate, but it would be nice to have one in the cab, and you can certainly get the idle close enough off of that. They run off the alternator.
