Idle speed?
Discussion in 'The Garage' started by my87Half-ton k5, Jan 17, 2006.
  1. my87Half-ton k5
    my87Half-ton k5 Registered Member
    Jan 9, 2006
    35
    NH
    whats the correct idle speed for an 87 tbi 350?..mine seems wicked wicked low since i swapped IAC valves but it runs perfectly smooth (thanks to a ****load of new parts) and has no hesitation whatsoever..my oil pressure is at least 30 when im idling even at this low RPM , so should i stop worrying?
  2. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    If it runs smooth prob. not a worry. There should be a white sticker under the hood with idle specs. Otherwise grab a book on her.Depending on your tranny it's somewhere between about 600 and 850 rpm. No stickers on my junk, if it feels right it is right.
  3. lamberthkp
    lamberthkp SITFU Premium Member
    Jan 17, 2005
    1,468
    16
    West TN
    i got a 89 tbi350 i idle at 600 rpm when warmed UP . :D
  4. my87Half-ton k5
    Jan 9, 2006
    35
    NH
    yea im talkin maybe 450-500 rpms right now cold or hot no difference but she goes as good as or better than before i changed the temp sensor
  5. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    dude mine revs too high it jumps kinda when i throw it gear so if i change my iac valce it should idle down some or wat dont mean to jack ur thread by the way
  6. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    My 89 idles at 500 rpm too. However, thats way too low for the cam I've got in there, and she bumps and sputters at red lights like she was some alcohol top fuel dragster.
    You can mess around with minimum air / throttle screw to force it to idle higher, but that can mess around with other stuff. Proper way to adjust it is to change the target idle RPM in the prom.
