idle stop solenoid
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blaize, Apr 1, 2000.
  1. Blaize
    Blaize Registered Member
    Feb 24, 2000
    45
    Torrance, California, USA
    Shouldn't the idle stop solenoid have 12VDC at the electrical connection when the ignition is on and the engine cold ? I am not measuring any voltage when cold, and I am having "fast-idle" problems. I have oiled the throttle linkage, and just put in a new idle stop solenoid, but the plunger is not plunging ! Any suggestions ???
    Also, the green wire going to this solenoid disappears into a wiring harness, but where does it originate ? I'd like to check for continuity...
    thanks !
    Blaize
  2. Eagle86K5
    Eagle86K5 1/2 ton status
    Mar 5, 2000
    974
    Whitehouse, Ohio
    try running the A\C, that is what it is for , to bump up the idle to compensate for the load of the A\C compressor
    <font color=green>Eagle86K5[​IMG]
    <font color=red>Only guy I know that can get out of line in a one car funeral
  3. Blaize
    Feb 24, 2000
    45
    Yep, Eagle86K5 pinned it ! Thanks ! Turning on the AC energizes the solenoid. Also, I used Berryman "B-12 Chemtool" to spray clean the carb and throttle linkage, wow !, what a difference ! My idle is awesome right now, I guess the linkage was pretty gummed up. Anyways, thanks for the help !!!
    Blaize
