Idle surging
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 89K5guy, Jan 24, 2006.
  1. 89K5guy
    89K5guy 1/2 ton status
    Jul 11, 2005
    174
    Ohio
    When I am at idle especially in drive, the idle surges up and down.Any ideas on what to look for?:confused:
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Start by looking for vacuum leaks. Replace any lines that look questionable, then use a small propane bottle to search for leaks. Do not light the propane, just turn it on and point it towards various items on/around the intake. If the idle increases/smoothes out, then you've found the leak. The propane will be drawn in at the leak and stop the leak from making the fuel/air ratio too lean.
  3. K5Greek
    K5Greek 1/2 ton status
    Nov 25, 2005
    2,054
    Vineland, NJ
    Im having the same trouble with mine. Ive replaced the 02 sensor, wires, plugs, egr, new thermostat(put new rad. in) and Ive checked for leaks with no success. Not sure what to do here either
  4. MuddQueenK5
    MuddQueenK5 Registered Member
    Oct 15, 2005
    84
    Glenside, PA
    Another method you can spray carb/TB cleaner in "trouble areas" and it's the same principle, if the RPM's go up then you have a leak.
  5. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    how can you check for vaccum leaks????
  6. MuddQueenK5
    Oct 15, 2005
    84
    Glenside, PA
    I think he is saying to take propane (don't light it obviously) and just run it over the vac lines. If the idle goes normal then that area is the cause?
    You may also be able to use soapy water. Just spray problem areas (where the vac lines connect or possible kinks) if you see bubbles, then you know where the leak is.
  7. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thanks
  8. chevyk2500hd
    chevyk2500hd 1/2 ton status
    Nov 24, 2005
    192
    Lafayette, Indiana
    You can't use soapy water. It is called a vacuum leak for a reason. It will suck the water into the engine not blow bubbles. I don't recommend doing this. Carb cleaner or starting fluid are good choices.
