Idle too fast - not passing CA emissions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rampage, Mar 20, 2001.
  1. rampage
    rampage 1/2 ton status
    Mar 20, 2001
    2,260
    72
    Humboldt/Pacifica, CA
    I have an 89 fullsize Jimmy with a stock 350. My problem is that I am not passing my CA emissions test because it is idling at 1425 rpm and aborting the test (and yes the engine is at normal operating temperature during the test). There is no "service engine" light on so instead of having someone charge me $100 to hook it up to a diagnostics machine I purchased one myself for an un-goddly price, but I will have it forever! Now when I view the output from my ECM I can see what the computer is seeing for all the sensors in realtime. What I see, amoung other things, is that the coolant temp is at 185 (normal), rpm when in gear at 0mph is 800rpm, rpm in park after driving for 30 mins is 1200 rpm. Immediately after I take the last rpm reading I turn the engine off and then back on and the rpm is now at 1425 again. What is the normal rpm at idle that I should be looking for and most important, how do I correct this so I can pass the strict CA emissions test. I have the service manuals but I need someones help fast who knows exactly what the problem is because I'm driving without a registration now!
  2. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    What kinda carb do you have? A quadre jet?
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    It would be TBI on an 89...
    Throttle position sensor maybe?
    Rene
    [​IMG]<A target="_blank" HREF=http://jules.coloradok5.com>http://jules.coloradok5.com</A>
  4. rampage
    Mar 20, 2001
    2,260
    72
    Sorry, I missed that info and maybe more too. It is TBI and fuel injected.
  5. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I would try runnin a can of berriman's through your gas tank to clean everything up first, but if that doesn't help then I wouldn't be a whole lot of help. I'm sure it's some sensor. I've got a '79 and I like the simplicity [​IMG].
  6. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Start looking for vacuum leaks first. The Idle Air Control motor can only do so much to restrict air from entering the engine. Once it's closed, it's closed. [​IMG] Air entering through leaks can be enough to raise the idle speed.
  7. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Isn't living in Cali a b!tch? Smog laws, Ha I spit on them....
    <font color=blue> Yesterday was history,tomorrow is a mystery,and today is a gift. -Taproot- </font color=blue>
  8. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    What part of cali are you in? I have a mobile mechanic rebuilding my carb right now, in northern cali. He specializes in carbs, fuel injection and emissions, did smogs for years and worked for GM, if you can handle him being a little scarey looking, he is extremely knowledgeable.
  9. rampage
    Mar 20, 2001
    2,260
    72
    I live in Burlingame, just south of San Francisco ... and I don't mind scarey looking people, as long as he can get me to pass the test!
  10. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    Take a look at adjusting your TPS ( about 5 minutes with a multi meter). I had a bad one that was causing high idle speeds.
    [​IMG]<font color=red> Elkboy</font color=red> [​IMG]
  11. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    Okay, I checked into this for ya. There is a solinoid on the throttle body that controls the idle. Usually called an idle speed solinoid. It is either sticking, faulty, or getting a bad reading from a sensor. The trick is to figure out which thing it is, but that might help narrow it down. It sounds like it's sticking which would mean you need to replace it.
  12. rampage
    Mar 20, 2001
    2,260
    72
    But wouldn't a bad solinoid also make it idle fast when in gear? It is idling at 800rpm when in gear but at 1400rpm when in park.
  13. muddin4fun
    Feb 19, 2001
    5,644
    N Texas
    I dunno. There's no tellin'. You might check into sensors that that solinoid runs off of. There's no tellin' what those things are telling it to do. Just my .02. I'm not really great at TBI. Well, not really good....well....I suck at TBI. I don't know which sensors it runs off of. Man! I need to shut up! I'm confusing myself! I'm just passing info along from what I heard somewhere else.
  14. rampage
    Mar 20, 2001
    2,260
    72
    I welcome any and all advice .. 1st, 2nd and even 3rd hand info. I'll be checking all the suggestions as soon as I can ... and get back in touch with the winner of the prize money!
  15. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    I'm thinking an Idle Air Control valve problem, or a Throttle Position Sensor problem. Maybe a leaking throttle body-intake manifold gasket?? I think you can spray a little carb cleaner around the base of the TBI and if the idle jumps up, you've got a leak. Here's one from left field... the Park/Neutral switch. My Haynes says the switch controls a few things and problems with it can cause "idle qualith will be adversely affected".
    [​IMG] Semper Maintenance!
  16. rampage
    Mar 20, 2001
    2,260
    72
    I'll try that card cleaner trick.
    I don't think it's the park/neutral switch because the diagnostics readout indicates that it's not in gear, but ya never know!
  17. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    You ever consider it's the person doing the test? Two years ago I took my Blazer to a place...failed, guy wanted bucks to fix it. I got frustrated and left. I called a friend who does engine work and had him look at it to see if he could do the repairs cheaper. He asked me where I took it and told me to take it to another place. It passed there no problems. I am not trying to say anything bad here...but this first place got shut down here recently (I drive past it everyday going to work). I think they were BS'ing folks and got caught.....might wanna check that out for you as well.......
    "I love the sound rice burners make when ya run over them"
  18. Nrose07
    Nrose07 1/2 ton status
    Mar 29, 2000
    267
    Salem ,Or
    Well since I haven't seen this posted yet so I will. Idle in park 750, in gear 600.
    With your handy dandy little scanner hook it up when your Blaazzer is cold, start it up and watch your scanner, when the computer goes into closed loop operation see if your idle changes. If the idle dosen't change or at least by the difference you describe look at these areas. 1.Oxygen sensor, have you replaced? No, do it. 2. Check your exhaust manifold heat exchanger tube valve located in your air filter assembly. See if during your driving is becoming stuck in the open position, sucking in hot air. 3. Is your power brake booster developing a leak after some consistent use (after driving around for 30min)? 4.If you are still stuck find a deq place close, drive there, park, through a bag of ice on your motor, sit, sit, sit some more, motor cold? Go in have them test it, and hope they get done before your high idle shows up. Hope this helps!
    Displacement, cubes, and did you say you drive a riceburner???
  19. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    If I recall right, there is a separate passage in the top of the throttle body where the air that goes through the IAC comes in. While the engine is idling high, you should be able to just put your hand over that passage, and block the air flow. This will tell you real quick if it is the IAC that is causing the problem. The passage is at the rear passenger side corner of the TB, right above where the IAC screws in. Otherwise, look real close for other vacuum leaks.
    Tim
    70 Blazer CST 4X4 350 SM465 NP205
    87 Burb 4X4 350
    01 GMC 2500HD 4X4 Duramax/Allison
  20. rampage
    Mar 20, 2001
    2,260
    72
    ChevyCaGal : That's what I thougt at first too because before the guy did the test I had to wait a while for him to show up (maybe he was late to work that day), and I thought my engine cooled down too much. But when I got my diagnostics scanner it confirmed exactly what he said ... idle at 1425rpm. But I do think that they were going to rip me off with the repair bills ... $90 to hook it up to diagnostics scanner, 3 hours labor and a possible $250 for parts ... yeah, right!!! Do I look like an idiot?
