idle
Discussion in 'The Garage' started by 69K5, Nov 14, 2002.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    my truck is idleing roughin gear at lights ect. purrs in park or neutral. im having a brain fart here. i know i have fixed this before. by the way its a 350, HEI, headers, and a starter that gets too hot.
    thanks
    nathan
  2. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    Check for vacuum leaks. A small one may let it run fine with no load, but suck too much air under load causing it to run rough. I know that worn throttle shafts will cause this, but if it just started doing it then there may a loose vacuum line somewhere.
  3. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    I agree with the leaks. Double check your vaccum routing. I had the exact same symptoms, rerouted and replaced hoses for about $15, and now it runs like new. Couldn't believe the difference. My vaccum diagram was gone from under the hood, so I printed one off of AllData.
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    thanks ill check it out
    nathan
