idling rough and balky from a stop all of the sudden?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 72beater, Jul 12, 2003.
  1. 72beater
    72beater 1/2 ton status
    Oct 11, 2002
    224
    Nation\'s Capital
    The beater just starting idling roughly and acting hesitant when I take off? I'm thinking carb but any idea where to start? it's a carter comp 4 barrel. any ideas?
  2. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Try pulling back a quarter turn on the idler screws on the carburator while the truck is at idle and see if that helps, if it does, take them back in 1/8 turn and find out where your best idle is.
    -Andrew /forums/images/graemlins/usaflag.gif
  3. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    I'll try that. Thanks.
    -Ernest
  4. clubba68
    Dec 6, 2002
    1,511
    Did it help?
  5. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    If it just started all of a sudden did you check the plugs for symptoms (some sort of deposit, oil or ash)? Could the timing have changed?
  6. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    I have a hook up and can get JET PERFORMANCE Stage 2 carbs for $150.00 rebuilt...
  7. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    well, I adjusted the carb and the problem is still there. I guess I'll pull the plugs, check the timing, etc. On top of this my battery just went belly up too! oh well, old trucks!
  8. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    ok, it's not the plugs, wires, dist, points, coil, etc.
    I'm thinking carb for sure now. I have checked for air leaks, etc, but am now out of ideas. anyone?
    -Ernest
  9. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    hate to sound like a lamer, but have ya looked at the fuel filter(s)? might be a slow fuel feed.
  10. 72beater
    Oct 11, 2002
    224
    Nation\'s Capital
    good question, but I did check that. I'm buying a rebuilt carb from a guy and throwing that on, and I hope that solves it.
    -Ernest
  11. Topdown
    Nov 26, 2002
    2,598
    hmm... good luck!
    I had a similar problem with my previous engine... couldnt find the problem anywhere! /forums/images/graemlins/angryfire.gif
    Lucky for me the cam went flat and 6 of the 8 rod bearings were shot so I built a new engine. No more stumble off idle. /forums/images/graemlins/thumb.gif
