If God had a 4x4
Discussion in 'The Garage' started by Brocky, Nov 7, 2005.
  1. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    Would God use these axles? They are different and sweet. I imagine they are not cheap. http://www.overkilleng.com/
  2. MOBK5
    MOBK5 1/2 ton status
    Apr 5, 2005
    180
    MCAS Cherry Point, NC
    All of those internal u-joints look like fun.
  3. gn4u2c
    gn4u2c 1/2 ton status
    Oct 29, 2003
    287
    Pa 17329 zip
    buy rockwells call it good
  4. Brocky
    May 22, 2005
    1,170
    I wouldnt want the headache of replacing them. Thinks long and hard about replacing my front u joints. Maybe because I dont have a garage, maybe I am just lazy, or both. Working outside isn't nice none the less. And today is one of those quadrabog days. Trying to get the rig running without blowing black smoke.
  5. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    i think i'd rather have mogs over those.
  6. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If god 'wheeled he'd point and laugh at those axles because he realized how often those joints would break.
  7. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    Could ya'll imagine if one of those U-joints shattered inside the 'tube'??? You'd be stuck on the trail!!
    A+ for effort, but I don't think it'll catch on. Portals are better - the internals are in the right planes with them.
  8. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Gimme a pair o' Rockwells or Dana 60's anyday. Those things are just gimmicky and too complex looking.
  9. MrArmyAnt
    MrArmyAnt 1/2 ton status
    Dec 29, 2004
    662
    Texas, Kick a$$! (Grapevine, DFW; also Norman, OK)
    I know hummers do a wierd thing, dont the drop the tire down? always though someone should thing of a way to add a chain to the axel, going down an arm onto a tire, that real ground clearance cold be incredibly high, or gear it that way. Only problem is the stress that would be put on that plate to hold wheel to axel. anyone understand me? a pic might help if i draw one...
  10. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If those broke on the trail, you would definately need a higher power to get home. Or maybe a Chinook. :D
  11. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Do people break 1480 u-joints often ? The idea is great , and people in AZ could run those and not break them , our rocks aren't slippery :D:D
  12. LVJimmy
    LVJimmy 1/2 ton status
    Aug 22, 2005
    301
    Lost Wages, NV
    Chain drive
    They use a chain drive set up in the logging industry. 40" tires 96" of clearance at the diff. You can straddle a tree 36" tree trunk pick it up and move it.
  13. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    I think those are very cool - but I think portals are probably a little less complicated. I think http://portal-tek.com/ has some potential.
  14. 350k5
    350k5 1/2 ton status
    Feb 15, 2005
    115
    Bloomington, IN
    Overkill Engineering huh... At least the company name reflects their product. :rolleyes:
  15. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    look around on Pirate there is a thread about it. piece of junk really. I forget but ther were a few things about it that were total crap(besides the ton of u-joints to fail).
  16. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    i read it too. http://www.pirate4x4.com/forum/showthread.php?t=397189&highlight=overkill+engineering
    its hideously expensive and people have seen it up close said its poor quality. the price is even worse 5000$ for a rear with a locker 7500$ for the front with locker!! :yikes:
    not worth it at all but thats just me
  17. Brocky
    May 22, 2005
    1,170
    The guys(JEEPERS) here all fell in love with the idea. Personally I think a 60 and 14FF is enough. I could only imagine tearing one of them up under power. I think you would need to burn the axle open to fix it. :D
  18. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    why would you be stuck if the u-joint broke in the tube ? looks like the cover comes off the tube to me...simply remove the screws.. PITA maybe, but do-able. :confused:
  19. muddyblzr
    Nov 2, 2004
    623
    if you blew up a u joint in that thing i see it tearing up alot of stuff. and theres just alot more weak points and places for it to fail. that housing is made of aluminum think about what would happen if you had chunks of u joint flying around in there
  20. Fubeca
    Dec 18, 2002
    2,100
    Denver Area
    Take a look at the pirate link - the housing is made of steal and its heavy.
