If I can't fix it I'm going to shoot it.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by OhioJimmy, Aug 23, 2000.
  1. OhioJimmy
    OhioJimmy Registered Member
    Jun 21, 2000
    92
    just moved to Kansas, Hoisington
    If I can\'t fix it I\'m going to shoot it.
    I'm having a problem that has me stumped, The more throttle I apply to the engine the worse it bogs down, I have more power at half throttle than full. Also when I start it in the mornings it runs great, high idle works fine its just when i actually apply the gas it sputters coughs spits and complains. it does this warm engine or cold. I think its in the carb, what do you guys think. 86 Jimmy 305 quadrajet, 700r4. I have replaced cap, rotor, plugs, wires, fuel filter, air cleaner, pcv valve, two cans of carb cleaner, stp fuel system cleaner,high octane 90, wished, prayed, and waxed it because I thought it might be mad at me. Please help, what am I overlooking.
    When the mud gets deep and the hills get steep we'll find out who bought the parts that were cheap.
  2. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Re: If I can\'t fix it I\'m going to shoot it.
    Could be the fuel pump or a restriction in the carb jets. Maybe leaking accelerator pump?
  3. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    It sounds to me that your engine is starving for fuel.[​IMG]. Have you checked the fuel pump? Try and remove the fuel line from the carb, get a container and have someone crank the engine for you to see what kind of volume you're getting. Oh yeah disconnect the power to the ignition so it does'nt start first. If its not getting enough fuel the more you open it up the leaner it will get.
  4. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    Hate to break it to you, but you may have done yourself in with that fuel system cleaner. That crap is great at cleaning your gas tank out, but guess where it gos after your gas tank. Strait into your carb. Ok, maybee the fuel filter will get alot of it out, but it does not take much to gunk up a carb these days. If I were you, I would check the fuel pump first, and if that is all good you may want to rebuild your carb. It is not too difficult, but it takes a long time. Also, make sure and use an acid bath of some sort. Then rinse it in water and blow dry it with compressed air. It will run like a new carb when you put it back together.
    78 K-5
  5. Grim-Reaper
    7,385
    Atlanta
    Well 2 possible problems. 1st being that the Choke is not fully opening. Thats an easy fix. Either the linkages are gummed up or the thermostatice deal on the side is failing.
    I'm going to assume you put a new $1 fuel filter in.
    The second problem is you should have the POS electric mix control carb. Those things are notorious for screwing up. If you don't find it's the choke fins a carb from like a 79. it doesn't have the electric BS and it has the correct vacume ports to run you smog gear. It can easily be converted to electric choke by swaping the element off the old carb.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  6. realsquash
    realsquash 1/2 ton status
    Jul 12, 2000
    778
    SE WI
  7. OhioJimmy
    Jun 21, 2000
    92
    Yes I actually just timed it today and it was on the money, checked the fuel pump and it pumps like crazy, choke is open, so I guess I'm due for a rebuild. Thanks for all your help guys I'll let you know how it turns out.
  8. archer
    archer 1/2 ton status
    Aug 17, 2000
    136
    tn
    I had the exact same problem, it was two fold. Funk in the gas tank and a bad catalytic convertor. When I'd get up to highway speed it would die due to the crud in the tank, and it bogged whenever I applied the gas due to a melted catalytic convertor. I pulled and cleaned the tank, then disconnected the exhaust ahead of the cat. Runs like a scalded dog now.
    "who dares wins"
  9. chaka73
    chaka73 1/2 ton status
    377
    Southern California
    Hey Ohiojimmy if you do decide to shoot it can I join you? and I'll let you shoot my differential it's dying anyway just for fun good luck man.
    check out my new site, thanks Steve!
    http://chaka73.coloradok5.com
  10. Hayduke
    Hayduke 1/2 ton status
    May 9, 2000
    271
    NE Columbus, Ohio
    hey OhioJimmy,
    my '86 305 Jimmy is doin' the EXACT same thing, has me stumped too. she's goin' to the shop next week to figure this one out....
    HAYDUKE
    Insured By COLT, Policy #.357M
    http://haydukesk5.coloradok5.com
