If I had a time machine (frame rivets)
Discussion in 'The Garage' started by dremu, Nov 12, 2005.
  1. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    I would go back in time and beat senseless the guy who decided to use rivets on the suspension on my K5. I don't care that bolts come loose over time; rivets are a major PITA to drill/grind/remove. I am this || close to going and getting an oxy/acetylene torch even though I can't afford one.
    That, as RJ sayeth, is all.
    -- A
  2. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    are you in concord ca? If so im not that far from you and I have a torch. :D
  3. dremu
    Feb 27, 2000
    15,958
    452
    That's the one ... sh!t, I wish I'd thought of that earlier =))
    I'm halfway through now ... if the driver's side gives me grief I'll shoot you a PM. I figure at least I'm outside getting some fresh air (and some grinder sparks up my nose :D ), right?
    -- A
  4. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    that works. Maybe Ill have my tranny done some time today. :rolleyes: If I can get away from this computer.
  5. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    dont bother me at all. just fire up the tourch and take time not to nick the bracket or frame. :D then when thay are red hot after head is melted off hit them out with hammer and punch.
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Geezzz....Pick up a GOOD air hammer (IE Snap-On quality) and rivits are easy. :wink1:
  7. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    I have always had good luck cutting an X in them with a cut off wheel and then hitting them with an air chisel to knock the head off. Then use a center punch and BFH to knock them out. Oh yea, use a pair of vice grips to hold the punch. Hope this helps.
    Ray
  8. dremu
    Feb 27, 2000
    15,958
    452
    Yeah, and the $$ is likely about the same as the torch. 'Sokay, I have more time than money right now ... :D
    -- A
  9. dremu
    Feb 27, 2000
    15,958
    452
    LOL ... the vice grip tip is particularly useful! =))
    The problem is the rivets in the rear L-bracket on the front spring hanger ... I'm doing the 52" swap up front, and it's impossible to get ANYTHING in there, especially on the driver's side. Those four I ended up drilling out 'cuz it was the only tool I could get past all the obstructions.
    As I said, time ... time ... :doah: But it's done, woohoo!
    -- A
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    For those I just knocked the heads off of the inside of the frame :p:
  11. k204dr
    k204dr 1/2 ton status
    Aug 27, 2004
    463
    TN
    They are definately a bitch. you can get a air hammer at harbor freight for about $5 and tax. they work as good as any airhammer. in fact, it worked better than my friends $150 mac tool one he had just bought!
  12. jays68yak
    Feb 27, 2003
    973
    Gilroy, CA
    Think out of the box and then you dont have to move it. :D
  13. dremu
    Feb 27, 2000
    15,958
    452
    Dontcha mean "Think about boxing it in"? :haha:
    I'm not in a rush to lift the truck more ... figure I'll do it a bit at a time, see how it goes.
    Though that is sweet. :thinking:
    -- A
  14. mciahpv
    mciahpv Registered Member
    Jul 8, 2005
    97
    Gator Country
    AIR HAMMER AIR HAMMER AIR HAMMER
    Borrowed one from a friend with a sharp chisel head on it, that sucker went through those rivets like grandma through a herd of cattle.
    Yes, that's good.
  15. dremu
    Feb 27, 2000
    15,958
    452
    LOL. Umm, is it common to have grandma-and-farm-animal issues in FL, or are you not native? :D
    -- A
  16. dremu
    Feb 27, 2000
    15,958
    452
    Can't get inside the frame, cuz some red-headed idiot put a hidden winch in there. :rolleyes:
    OTOH, I have an el-cheapo air hammer, and the best I've found for it is popping the rivets through the frame, once the head has been ground/cut/whatever off.
    I'll be picking rivet heads out of my yard for months, but it's worth it to watch those little fuggers fly off :haha: I win! :D
    -- A
  17. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    I agree... even with my home depot cheapo husky air chisel... and a sharp chisel.. I can do rivets in 15 seconds or so... I dont even bother with the torch...
  18. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    i cant beileve you guys got it so rough! it took me a total of 30 minutes to remove both brackets. i just ground the heads of and then took my hammer (3lb sledge) and a big flat bar and hit it between the brackets and the frame. a little prying and they came right off. i even rmove both the mount and its gusset at the same time. (I left the shackle in place cause i used longer ones)
  19. 79k20350
    Nov 22, 2004
    7,757
    Ct
    where did you get those spring mounts?
  20. Jagged
    Jagged 1 ton status
    Apr 25, 2005
    11,460
    SWVA
    Did you fab that perch?
    You still had to remove that bottom bracket, right?
