if i press the brakes and my idle changes does this mean vacum leak???
Discussion in 'The Garage' started by down4thakrown, Jul 30, 2005.
  1. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    on my DD when i press the brake pedel the idle changes. does this mean i got a vacuum leak? possibly just a wore out hose?
  2. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    a tiny change is normal but that usualy isnt very noticable. id say it its real noticeable its probably a vaccume leak. you can use carb cleaner to check for leaks lightly spray arond hoses and fittings while its running and listen to the engine. if the engine speed changes inspect the hose or fitting you just sprayed
    balzer
  3. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    That's normal (as long as it's a small change in idle that last a few seconds.) It's just a change in manifold vacuum as you suck the servo diaphram in. If it's a big change in idle speed and is high all the time you have your foot on the brake I reckon it'll be your servo leaking.
  4. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    WOW... did we type that at the same time?? SPOOKEY!!! lol :D
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    Talk about being "on the same page"...:eek1: :D
    Rene
  6. diesel4me
    Jul 24, 2003
    17,547
    937
    Massachussetts
    listen closely...
    All the GM trucks I had with bad power brake boosters not only had little or no power assist,the engine would stall or idle rough as long as you applied pressure to the brake pedal,and you could hear a hissing noise under the dash near the steering colum..
    There is a bolt hole in the master cylinder casting on the bottom rear--on 67-72 trucks they used that hole to mount the brake proportioning valve,but later trucks still have the hole there--my trucks that had vacuum booster failure(ruptured diaphram) you could hear the vacuum "leaking"(sucking??) in that hole--I found it by spraying carb cleaner in the bolt hole! :eek1: --
    There is a smaller hole that goes to the rear of the master cylinder casting from that bolt hole that you cant see when the master cylinder is bolted to the booster..not sure why its there,but I guess it serves as a "vent" for the vacuum when the diaphram fails,or maybe its to let air in so the diaphram can return to its normal position when the brakes are not applied?...at any rate,when the diaphram fails,you will have a vacuum "leak" at that bolt hole in most cases.. :crazy:
  7. Stoner42
    Stoner42 Registered Member
    Jul 17, 2005
    15
    Williston ND
    Vacuum leak would be in the brake booster- nowhere else with that condition.If it was elsewhere engine would always idle high.
  8. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    I am guessing you have a booster vacume leak, or a booster on its way out. It happened to me about 3 months ago.
  9. blownout
    blownout Registered Member
    Jul 19, 2005
    18
    ont.canada
    no way
    no its fine the truck is old .
