If I wanna run UCP next year I have to.....???
Discussion in 'The Garage' started by MudNurI, Aug 12, 2002.
  1. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    I took enough slack from you guys when I told you how many miles mudnuri has - then you found out it is a 305, then I opened my mouth and told you it was 1/2 ton..... so next year your gonna be in for a suprise...the 305 is coming out....if I have my way- it will be a big block going in, but John says "350 is all your gettin"...so sounds like the engine is done...It'll be fuel injected. I don't wanna "run outta gas" like Josh did.......
    You guys balked at my 208 as well, SO..guess I need a different one.... which one?
    I'm NOT going 1 ton. so 3/4 ton it will be.
    what else do I need. I will not be doing the nasty q or M trail or any of that stuff...but want to run more than stock trails...
    add to my list folks.
    Brandy
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    get a np205 for the t-case and get a detroit for the 14ff /forums/images/icons/smile.gif
  3. Donna
    Donna 1/2 ton status
    Feb 20, 2001
    2,377
    Gettysburg,Pa
    where should I start??
    bigger tires
    lift
    1 ton axels
    spare u joints
    This is my Christmas list....what else should I ask for?
  4. Rebel88
    Rebel88 1/2 ton status
    Sep 7, 2000
    1,855
    Richmond, VA
    actually you can run the 208 if you want to...its got a lower ratio than the others out there plus its a hell of a lot lighter...you just need to worry about the slip yoke if you have some extreme flex
    all im running is a 208 and you saw how many problems i had with it...none
    Later
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Don't ask Pete about a 208. /forums/images/icons/crazy.gif
  6. yunit
    yunit 1/2 ton status
    Feb 24, 2000
    3,068
    Oakland, NJ
    The only thing in my truck that is going to have anything to do with the number 8 is the bolt pattern on the back of my 205. Plus I can only count to the following numbers. /forums/images/icons/tongue.gif
    two : one /forums/images/icons/grin.gif
    four : one /forums/images/icons/grin.gif
    fourteen /forums/images/icons/grin.gif
    thirty eight and a half / fourteen and a half/ fifteen /forums/images/icons/grin.gif
    sixty /forums/images/icons/grin.gif
    two hundred and three /forums/images/icons/grin.gif
    two hundred and five /forums/images/icons/grin.gif
    three hundred and fifty /forums/images/icons/grin.gif
    four hundred /forums/images/icons/grin.gif
    four fifty six /forums/images/icons/grin.gif
    fourteen ten /forums/images/icons/grin.gif
  7. Mr.Chevy4x4
    Mr.Chevy4x4 1/2 ton status
    Jun 16, 2000
    1,932
    Sims, NC
    You forgot two important numbers that do include "EIGHT"!
    Eight Cylinder
    Eight Lug
    /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif /forums/images/icons/grin.gif
    Mike
  8. yunit
    Feb 24, 2000
    3,068
    Oakland, NJ
    I knew I forgot something. /forums/images/icons/tongue.gif
  9. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    why just 3/4 ton? do it right,do it once. talk to wayne and get him to hook you up with some one tons. locked and geared and be done with it. ready to drop in for under 1800, then pick up a set of $20 rims and tires.
    its a long drive but worth it.
  10. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    $20 wheels and tires. /forums/images/icons/shocked.gif
  11. MudNurI
    Jul 15, 2001
    2,113
    VT
    Why would I need 1 ton? I'm not going to be doing any hard core wheelin. More than likely what I will wheel is in Paragon, once a year when Wayne and Donna have the UCP. Here in VT, we don't have rocks etc... we play in mud more than anything else.
    $20 rims/tires. Man, you guys might have expensive beer down there, but your sneaker's are cheap!
    Maybe I'll have to get wayne to build me a set of axles, and come down next year a few days early, and put them in....hmmm now that's a thought.
    Wayne- what do you want to build me?
    Brandy
  12. Rebel88
    Sep 7, 2000
    1,855
    Richmond, VA
    hey look at me...you dont have to go 1 ton...im 3/4 and i did alright...
    its all about the driving finesse...and the cowboy hat /forums/images/icons/grin.gif
    Later
  13. MudNurI
    Jul 15, 2001
    2,113
    VT
    I think you are 1 of the VERY few that ended up with ZERO damage....
    I think 3/4 it is... man should NEVER have swapped back to a 1/2 ton with the guy I bought it from!
    going to Texas to get me a cowGIRL hat for next year, I see that makes so much difference!
    Brandy
  14. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Well if you ask Boss or Yunit you need a tow rig. Anything else.....what the other guys said /forums/images/icons/grin.gif .
  15. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    the 3/4 D44 is the same as a 1/2 ton 44, just bigger brakes.
    the 14bolt is indestructable so no loss there, but i feel safer with a 60 out front.
    just my two sense. i have yet to beat on the truck so maybe so-far the 60 is overkill, but i got sick of wiping out 44 spindles.
    Ryan
  16. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Well I think I did pretty damn good with stock 10 bolts. /forums/images/icons/blush.gif Actually Brandy you should be fine with a set of 3/4 tons. I think having a locked 14ff in the rear is the big key to it all.
