If I was to..
Discussion in '1982-Present GM Diesel' started by Paxx, Apr 21, 2003.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    put a 6.5LTD into a K5, would I be mating it to a nv4500 or a sm465? or would they both work? /forums/images/graemlins/confused.gif
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    I know the 4500 would bolt up since you could get one from the factory behind a 6.5 and I'm pretty sure that the 465 will bolt up also since the 6.5 and the 6.2 are pretty similar....
  3. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    would there be any problems making the nv4500 fit?
  4. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    You'll probably need an aftermarket bellhousing (or so I've been told...)
    The factory NV4500 bell has the slave and stuff on the passenger side and what I've been told is that there may be front driveline interference. I don't know that for sure though.
    NP208 and NP241 with 32 spline inputs should bolt right up to the NV4500. Shifter location is a little farther forward than a SM465 so the floor hole will need to be modified too.
    Rene
  5. Oblin Goblin
    Oblin Goblin 1/2 ton status
    Apr 30, 2000
    205
    Davis, CA
    Fit shouldn't be a problem if you get an advanced adapters bell housing. They have the slave cylinder on the drivers side. I've done this conversion in my 6.2 Blazer so if you're serious about it PM me and I'll tell you everything you need to know.
  6. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    thnx for the replies. and yes I am serious about it just not yet. Still piecing it all together in my mind for now
