If it doesn't Fit, do you make it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Rollingthunder, Jun 27, 2001.
  1. Rollingthunder
    Rollingthunder Registered Member
    Apr 3, 2001
    15
    Slaton, Texas
    If it doesn\'t Fit, do you make it?
    I can't get my cross member for the trany to fit. I swapped out tranys and now the bolt holes are not up as far as I need them to be. Do I drill new holes? I hate to do that on the frame. HELP!!!!!!!!!!!!!!
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: If it doesn\'t Fit, do you make it?
    I had to drill new holes when I swapped from the Turbo 350 to a Turbo 400. Just drill 'em and bolt it up. [​IMG]
    <A target="_blank" HREF=http://www.angelfire.com/super/ThunderTruck>http://www.angelfire.com/super/ThunderTruck</A>
  3. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I agree,just drill new ones.
    <A target="_blank" HREF=http://community.webshots.com/user/beaterwhang>http://community.webshots.com/user/beaterwhang</A>
  4. donimator
    donimator 1/2 ton status
    Jun 11, 2001
    444
    Tacoma WA
    I had to drill new holes to make a 700r4 replace a 350. Just do it. No harm done.
    73 3/4 ton Chevy. 383 stroker, TH350, NP 205, 14bolt FF(Detroit), Dana 44(limited Slip), 6in. lift, 36x 14.5 super swampers
  5. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    I agree, drill it. But you might want to consider using a thick gauge metal plate as a backing plate to distribute the shock on this area.
    Just a thought, Shawnboy.
  6. AGM73k5
    AGM73k5 1/2 ton status
    1,246
    Portland OREGON
    Did you change tranny models or just put a diffent unit of the same model in?
    -Aaron
    ___ __ _ _ ____ __
    AGM73k5 -- ajgm1@yahoo.com
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    i would just drill it
    77blazer see it at<A target="_blank" HREF=http://community.webshots.com/user/ssmith6333>http://community.webshots.com/user/ssmith6333</A>
  8. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    swapped in a th400, had to drill new holes. I also planned on running a brace down the frame rail to reinforce it.
    your right. I don't understand the jeep thing!
  9. jamiemac
    jamiemac 1/2 ton status
    Mar 26, 2001
    151
    Tennessee
    Drilling a hole is not a problem. Any time I change anything like that or get the chance while I have something apart I try to rplace all bolts with atleast grade 5 if not grade 8 bolts and nuts. Especially if It has been taken apart a couple of times. There is nothing any more agrivating than a bolt or nut that is rounded or rusted up. Or just plain damn stubborn..........
    Sometimes a little may help alot. Especally if you have to break it down on the trail. Your not all ways working in great enviroment anyways. So any help is allways needed!!!!
    Just my .02
  10. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Did a TH 350/203 to 700R4/205 swap had to drill new holes. Get the cross member all the way up to the frame and center it (measure from frame rail to output yoke on both sides). Clamp cross member to the frame and with a 1/2 inch bit just barely touch the frame to get a reference mark for the center punch. Center punch the mark and drill a small starter hole. Then work up to a 7/16" bit. I replaced my old bolts with 7/16" grade bolts, washers and nuts. The frames strong don't worry about the other holes.
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    How'd you hook an NP 205 to a 700R4? Did you have to change the tailshaft?
    Tim
  12. WOODYJ
    WOODYJ 1/2 ton status
    May 5, 2000
    144
    I switched from a TH350 to a 700R4. I put in an extra crossmember and just drilled new holes. Been in there for 5 years now with no problems. Hope this helps!
    k5woody I Don't Understand The Jeep Thing Either!!!
