if one converts an NP208 to fixed yoke would I be able to use the stock driveshaft?
Discussion in 'The Garage' started by big_truxx, Aug 29, 2005.
  1. big_truxx
    big_truxx 1/2 ton status
    Oct 8, 2004
    2,272
    Canaan, Maine
    anyone know?
  2. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    298? is that new? Whats the gearing like? :haha:
    you mean convert the stock yolk shaft to fixed yolk also? dont know the terms or if its possible, i just wanted to razz ya
  3. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    there mr smarty pants ;) :p:
    and you can convert a GM NP208 to a fixed rear output using the output shaft from a dodge NP208 ;)
    I was just wondering if it would use the same drive shaft as the normal NP208 in a blazer ;) :waytogo:
  4. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    You're gonna have to see if the yokes are the same size, but regardless, the shaft is going to be too short after the conversion, so you'll need it lengthened anyway with a slip added.
  5. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    the 203 is fixed rear output right?
    I had swapped in a stock driveshaft from a 79 k5 into the 81 k5 i had lifted 6" and 35's on... worked a lot better as the shaft itself is 2 piece and all ;)
  6. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    if you go from slip to fixed yoke you will have to get a driveline that has a slip in it instead of the yoke.
  7. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    so thats why the front driveshaft is slip :D cool
  8. big4x4ride
    big4x4ride 1/2 ton status
    Feb 11, 2004
    216
    Corpus Christi, TX
    just get the shaft from a dodge Ramcharger or truck and mdify it, that whta i did
  9. big_truxx
    Oct 8, 2004
    2,272
    Canaan, Maine
    one like the one i used in my 81 that was from a stock 79 w/ 305/350/203 should work fine.
