If You Had 1,000-1,300 Dollars To Spend
Discussion in 'The Garage' started by 1986chevy_rider, Nov 28, 2005.
  1. 1986chevy_rider
    1986chevy_rider Registered Member
    Nov 8, 2005
    97
    fallon nv
    What would you do if you had 1000-1300 dollars to spend on a 1986 chevy k-10 with half ton axels and old wore out 36" gumbo mudders with a fairly decent 6 inch super lift. Its also got a great 383 stroker that has about 3000 to 5000 miles on it. and a 465 tranny with a 308 x-case that is kind of wore out i think the thing makes a crazy knocking noise in four wheel drive. the other thing is that the drive shafts are stock. WHAT SHOULD I DO??? PLEASE HELP WITH SOME OF THE MONEY I AM THINKING OF GETTIN SOME 36" IROK SUPER SWAMPERS BIAS PLY.
  2. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Put the $$ in the bank and wait for something to break. When it does, fix/replace it.
  3. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    but i need tires bad
    what should i do in this case they sat on truck and didnt move for 9 months from what i was told
  4. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    First thing I would do is determine what type of wheeling I was actually going to do (not what everyone else is running). Once you determine that considering the price of new tires could easily take that whole amount of money. I would look on ck5 as well as locally for some good used tires. Just make sure they are worn evenly and at a descent price. If you find them then take the extra money and fix the tcase. If not bite the bullet and buy new tires.
  5. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I would make sure that everything mechanically is in good condition before bying the tires. No fun in having new tires on a truck with a busted transfer case. After you take care of that buy the tires.
  6. 1986chevy_rider
    Nov 8, 2005
    97
    fallon nv
    Yeah True
    Here is my thing. Its a daily driver as well as an extreme off road truck
  7. The Butcher
    The Butcher 1/2 ton status Premium Member
    May 17, 2005
    431
    43
    Texas. In a van, down by the river!
    Then I wouldn't get bias-ply IROKs. If it is a DD, get a radial tire. Swamper SSR, BFG Mud, TOYO M/T, Goodyear MTR, etc., etc..
    And like someone else said, it wouldn't do you much good to have great tires if your xfer case is busted. Get that fixed, then get some decent tires. Shop around and find the best deal you can. 4wheel parts was having a BFG promotion about 6 months ago and I got a set of 33" Muds for $600 mounted and balanced. I bet 35" would be about $700 with that promotion. Shop around between different tire stores, and make them give you the best deal possible. They love trying to beat each others prices!
  8. mini_mull
    mini_mull 1/2 ton status
    Jan 22, 2005
    1,198
    Queen Creek, AZ
    Fix the T-case, then swap out to 3/4ton or one ton axles. Otherwise if you switch to 36" and have a heavy foot with the 383, you could end up breaking the 10 bolts. It won't take up all 1300 if you only go 3/4ton, but then you'll have to change to 8lug wheels, unless you go 14BSF 6lug. Good luck. You can always send me what's left over. :wink1:
