If you Had to pick an engine
Discussion in 'The Garage' started by Saxwonder84, Jun 18, 2004.
  1. Saxwonder84
    Saxwonder84 1/2 ton status
    Jun 27, 2002
    117
    Rockwall, Texas
    I need despreatly to upgrade my dying engine, but I want something bigger. Being a college student money is tight but I don't mind saving for awile. So what do you guys think would be the best bang for my buck? Engine size and so forth. Thanks
  2. GORRILLA
    GORRILLA 1/2 ton status
    May 3, 2003
    315
    TX panhandle, out at the river.
    454, let me say that again,
    454.
    Even got a low mileage 454 I'll sell ya for $700, complete minus the power steering pump.
  3. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    just depnds on what you have to start with. odds are it is a 305. cheapest thing to do is get an overhaul kit and be done with it. or go to GM and pick up a crate motor and slap it in(way less time then messing with the old one)
  4. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    a healthy 350 or a stock 454...
    I went with a warmed over 454 and have never been happier..
    Chris
  5. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    after reading your post again...best bang for you buck
    a late-model 454 with about some mileage that has been taken car of...you could find one for around $1200 complete (at least I did) and running..put it in and run it...
    Chris
  6. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    i went with a 383... about 2600 for the long block Oil pan to intake.. Went with the Edelbrock RPM Air gap should be around 420 horse +420 ftlbs......... Aproxx
    then just use all the stuff on your motor water pump, alt, ps pump... might want a newer Distributor... Rebuild your carb, maybe put some bigger jets in it... of course there are odds and ends, but you should be good to go...
  7. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    tyhink caddy500, usually about 500 bones - Ebay /forums/images/graemlins/woot.gif
  8. Saxwonder84
    Jun 27, 2002
    117
    Rockwall, Texas
    wanted the caddy but hated the cost. To rebuild one well and get it in was looking like $2000. Where can I find a 454?
  9. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    "If you Had to pick an engine"
    If I absolutely had to, then I think I could be forced into one of these...
    GM Performance Parts Crate Engine ZZ502
    Horsepower: 502
    Torqe: 567 Ft. Lbs.
  10. Saxwonder84
    Jun 27, 2002
    117
    Rockwall, Texas
    Well unfortunatly it doesn't jive with my college budget
    Still wondering if any one knows where I can get a decent 454?
  11. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    350 or 383 with a roller valve train, TPI, as much of a torque cam as you can get away with, nice flowing heads, Thorley Tri-Y headers, dual 2.25" exhaust, etc.
    I have TPI and love it. My next motor will probably be something along the lines of what is above. A healthy motor with fuel injection.
    Harley
  12. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Your cheapest bet for a 454 is to buy a rebuild-able 454 core for the best deal you can find, go to a mail order company like this http://www.pawengineparts.com/ for a rebuild kit, then take the block, heads, crank, rods, new pistons, and piston rings to a machine shop to have the machining done, and bolt together the engine yourself.
  13. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Did anybody say it had to be a gas engine? Get an oil burner! Well there is that small complication of the gas/diesel swap, but worth it for a DD. And you're in Texas, no need for a block heater. /forums/images/graemlins/rotfl.gif
  14. bigyellowjimmy
    bigyellowjimmy 1/2 ton status
    Jan 15, 2004
    2,105
    Chandler, AZ
    Gorrilla posted that he had one for sale above, am I missing something or did you overlook it /forums/images/graemlins/dunno.gif
    /forums/images/graemlins/usaflag.gif
  15. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    I found a 454 up here it was in a el camino payed 500 for the whole car runs great (just had to put in a fuel pump) /forums/images/graemlins/woot.gif /forums/images/graemlins/woot.gifwas going to rip it out and throw it in the truck then i realized that it is a 73 ss and all the numbers match came with a 400 too so now i don't think i want to tear into it might be worth something /forums/images/graemlins/dunno.gif
    still have to look into it
    sometimes you never know what you'll find /forums/images/graemlins/waytogo.gif
  16. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    A 454 around here will bring 500 easy,even if it barely runs,anything with no holes in the block is like gold--I have seen a few bargains on big blocks at salvage yards in the C60 and larger dump trucks and box trucks--seems people dont care for the "tall deck"motors,or perhaps they think they are all 366's--I pointed a guy at one salvage yard toward a C60 truck that came from my town's DPW fleet when he said he was looking for ANY big block--a few minites later,the engine was on the ground---he scraped the grease off the engine codes and it was all zero's except the last 3 digits that were hand stamped into he block,they matched the trucks VIN # last 3 digits.Then he wiped off the valve covers,and a sticker appeared from under the grease--"Targetmaster 454"---the casting numbers on the bellhousing side confirmed it WAS a 454!! Evidently it had been replaced--the truck came with a 366.The yard sold him the motor for 200 bucks because someone left the hood open,and a little water came out of the intake when they pulled it.The guy had it running later tht day on his trailer---he didnt even buy me a beer! /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/doah.gif
    I look at every P series bread truck that comes in now too--I saw one go right in the crusher that I KNOW had a 454 in it--the loader operator said,"those things dont come with big blocks----do they????" /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gifYES!! They Do! and the come with cummings diesels too,I told him.He said,"Well,there all junk to me!"and in it went. /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif Another source of free 454's is to look for an old motor home--they have a hard time scrapping them,most yards here wont take them even if you are willing to pay--and many of the people who own them dont even know what size motor is in it!~.Its a bitch to get rid of the rest of the motorhome though,uless you can reduce it to metal pile size scraps and cash it in--alot of work,I've done it twice. /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/weld.gif
  17. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    look at the first post! shoot him a pm /forums/images/graemlins/waytogo.gif
  18. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    BINGO! Swap in a diesel. A 6.5 would work, a 6.2 would work, and a Cummins 4bt would work. There was just recently a 6.5 TD in the paper here for $600, complete running. I would have been all over it had it not been an electronic motor. 6.2's and 6.5's have a bad rap because of the old 5.7 diesel, so a lot of people will get rid of them for cheap.
  19. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    lots of power a little expenceive and it might be a little big but a moter from overseas might do the trick:
  20. diesel4me
    Jul 24, 2003
    17,540
    935
    Massachussetts
    Now THATS what I call a BIGBLOCK!!! /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/eek.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/yikes.gif
