If you install a tranny drain plug don't go generic!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by shum1, Nov 29, 2000.
  1. shum1
    shum1 1/2 ton status
    Oct 8, 2000
    270
    UTAH
    If you install a tranny drain plug don\'t go generic!
    I bought a 3.99 tranny drain plug from pep girls, It cost me ten times that in downtime. These cheesy things use a rubber o ring that tears as you tighten it, the threads are not tapered and they leak like crazy. I bought a 7.99 B&M unit which uses tapered pipe fittings no o ring and dosent leak. Save yourself some work and get the good one.
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    Re: If you install a tranny drain plug don\'t go generic!
    Thnaks for the tip, you can also buy a tranny pan with the plug already on it, but that would be more expensive. :)
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
