IFS 4WD actuator
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Leadfoot, Feb 26, 2001.
  1. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    Has anyone replaced the actuator on a mid to late 90's Chevy 1/2 ton pick-up. The light on the transfer case plate lights up in 4 hi and 4 low, the front driveshaft spins, but the front wheels do not move under power. I was told it is probably the actuator. I was wondering how hard it is to remove and replace and if that sounds like the correct thing that is wrong.
    Thanks in advance for any help.
  2. dyeager535
    26,979
    Leadfoot, depending on your vehicle, that could be a warranty replace item. For awhile, they were using some kind of actuator that locked the hubs by heating up and expanding. About the stupidest thing they could do, because in cold weather, or fording, the thing got cold, and instant 2wd.
    Dorian
  3. 85blaze
    85blaze 1/2 ton status
    Feb 20, 2000
    117
    Corning NY
    Its about a 20 minute job with all the parts.. But you have to run a new wire to the transfer case. THey make an electric actuator now instead of the old vacume style. I cant help out with details, A buddys truck broke down and he said its real easy... it kinda screws in with a couple hold down bolts if i remember right? Correct me if im wrong.
    Later
    Moshe
    Finally done after 8 months.. Not really.. IM never going to be done. Stroker motor is next
  4. schwinnd
    schwinnd 1/2 ton status
    Feb 26, 2001
    109
    SE Washington
    I just replaced the vacuum actuator switch on my wife's 97 S10 Blazer. When you push the button on the dash it sends a signal to open a vacuum line, which sucks a diaphram, which in turn pull a cable engaging the front diff. It was pretty easy. The switch sits on top of the transfer case. I had to drop the skid plate to get to the t-case, and its on the driverside rear of the t-case. Pop off the vacuum lines unscrew it and screw the new one in, put the vac. lines back on, bolt up the skid plate and thats it. I'm not sure if its the same as a full size p/u, just figured they may be similar. Good luck
    Just collecting rusty mid-70's chevy's
    1976 Blazer, 1975 Vega SW
  5. schwinnd
    Feb 26, 2001
    109
    SE Washington
    BTW the vacuum actuator switch was only $25.28 at the chevy dealership.
  6. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,792
    100
    Paducah, KY
    Go to the Standard Chevy/GMC trucks forum on <A target="_blank" HREF=http://www.off-road.com/chevy>http://www.off-road.com/chevy</A>, and take a look there. There are like 2 or 3 posts about this exact same subject from the last couple of days.
    1992 Blazer Sport, 350 TBI, 4L60, 3" Flowmaster, K&N, 3" Rancho, 285/75R16 on 16x8 Baja's[​IMG]
