IFS Front Coil Springs (not talking about rear leafs)
Discussion in '1992-Present Chevy & GMC models' started by Yohinan, Apr 25, 2004.
  1. Yohinan
    Yohinan 1/2 ton status
    May 21, 2003
    103
    San Diego
    Ok maybe stupid question here for me cause I am in learning mode when it comes to 4x4. I am coming from the car side of the house and learning rather fast. What I am wondering is when dealing with suspensions of cars you can purchase aftermarket coil springs with different spring rates, taller and lower springs, etc... allowing you to change a myrad of characteristics of your vehicle with just a coil spring change. When it comes to IFS lifts they cost an arm an a leg. Are there no companies out there that make taller coil springs to give more lift to our trucks (Suburban in my case)? If not I am wondering why no one has gone and found a manufacturer to produce some or looked at OEM parts bins for taller springs from different trucks that would allow more lift. I am talking on the smaller side of things here. I am not looking for a spring that will give 10" of lift if that is what you were thinking. I am being practical and saying maybe 2-3" from a coil spring change. Any input from anyone on this both negative or positive? I really dont want to shell out $500.00 or more for a lift kit when I could just get a small lift out of a spring change. Thanks for the help. John
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    there is no coil springs in a 4x4 IFS chevy. Pull the front wheel stand back and look at it then come back to us /forums/images/graemlins/wink.gif
  3. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    those trucks use torsion bars, the lifts come with raised control arms i beielve, im not totally sure what the lifts consist of ive never owned one but i know they are something like that when it comes to lifting them
  4. retroblazer
    retroblazer 1/2 ton status Premium Member
    Nov 30, 2003
    284
    158
    Gustine
    IFS lifts have been limited to drop brackets for the differential and the arms or a lower cradle to drop the differential and the lower arms, but leaves the upper arms in the stock location,using a new taller knuckle. The latter is the better method. The better kits have a one piece lower bracket as opposed to multiple brackets. These kits do nothing to improve the stock set-up other than lifting the truck.
  5. Yohinan
    May 21, 2003
    103
    San Diego
    A phrase comes to mind here. "OPEN MOUTH INSERT FOOT." Sorry about that one fellas. See what I get for opening the mouth before looking for myself. /forums/images/graemlins/dunno.gif Thanks and sorry for the idiotic question. John
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    no need to be sorry, everyone learns somehow.
  7. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    the 1 piece kits are the way to go if your planing on lifting it they are much stronger. You could prob find a way to make some brackets and what not to use coil springs for damping landings kinda like shocks hmmmm mabey.. /forums/images/graemlins/confused.gif
