IFS front Diff Gear Change
Discussion in '1992-Present Chevy & GMC models' started by kyser_soze, Apr 14, 2005.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I am going to switch gears in my 97 1 ton, and need the details for the front diff gear change. I have done the rear 14 bolt before but I need to know how to do the front. Any Advice?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    you have to take the whole front diff out and take the case apart ot change out the gears
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    What gears are you going to/from?
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    I took this (my) response straight off another post a week or so ago.
    There a PITA. Sometimes the stub shafts dont come out. You split the cases. To get the carrier bearings out its easiest to get the races out by putting the case halfs in a parts washer and it will expand and then beat them on the ground to get them out, or run a bead inside the race and flip it over and beat it out that way. Knock the pinion races out, new races in. pinion in and set the carrier in and bolt the halfs together, take out the vent plug, check backlash and pattern and adjust from there. NOt hard, just a pain.
    Also, DONT run Genuine Gear, get Sierra Gear.
  5. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    going from 4.10 - 4.88. Truck has 315's and I am wanting more pull power.
