IFS Lift Question
Discussion in '1992-Present Chevy & GMC models' started by ChevyHuny, Aug 31, 2002.
  1. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    I have a pro comp 4 inch lift for my IFS truck. With the lift comes 3.5 inch blocks for the rear. I was told that 3.5 inch blocks would make my truck sag in the rear. That I would have to add leafs and junk. I called Pro Comp and they said the truck would not sag and just 3.5 inch blocks are just fine.
    I dont know if the sagging part is true or not. . But if so why would the manufacturer put 3.5 inch blocks in the lift if it was going to sag? Thanks for any help /forums/images/icons/smile.gif
  2. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Ok hear is how it works. Your truck already sits high in the back. So the make the lift a bit lower in the rear to make it level not sag but level. These guys that design this stuff are like enginers and stuff so they kinda know what they are talking about. If it needed something else they would know the first time they did one. Thats why they get paid the big bucks.
  3. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Thank you Corey /forums/images/icons/smile.gif Now I know what Im going to do next will be okay. /forums/images/icons/wink.gif
    Cant wait to see the new paint job by the way. /forums/images/icons/grin.gif
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    What corey is saying may be true, however my brother in law just put a 4" superlift in his 96 suburban, and he had to add-a-leaf... he was sagging WICKED bad, not before the lift, but after......now it's not.
    our 99 rancho lift, we purchased the add-a-leaf kit because the rancho tech stated that the truck would sag without it....
    food for thought.
    Brandy
  5. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Thanks Brandy I will definatly keep it in mind /forums/images/icons/smile.gif
    I think that is why I like the Pro Comp lift so much. Ive talked to a few people now who have the Pro Comp 4inch lift for thier IFS trucks and so far they havnt had any sagging problems with just the blocks. I have heard that pro comps 6 inch lifts are not good though. Just the 4s. So If I ever decide to go bigger, I will go to a different company.
  6. scotty1
    scotty1 1/2 ton status
    Jan 7, 2002
    166
    WV, Harpers Ferry
    I was talking with the local trick trucks manager, about lifts for my 97 Tahoe, and he does not like the Pro Comp lifts anymore. He told me that Pro Comp had been bought out a couple of years ago and the quality and fit of the kits has suffered. He recomended TrailMaster, BDS and Sky Jacker. I had a 2" Superlift on my S-10 and the rear was an add a leaf, the factory springs were sagging before but after the lift it was worse. The fix was an extra lift shackle on the rear to make up the difference.
  7. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Hopefully it will work for me as it has done for other chevy owners with my lift. Ill make updates on how the Pro Comp lift works out for me /forums/images/icons/smile.gif
    Who was pro comp bought out by?
    If I was going for a big lift I would have gone with another brand as well. Im pretty confident now that my lift will be just fine for me /forums/images/icons/smile.gif
  8. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    I did not ask him who owns Pro Comp now but I will when I go in to talk with him about my options. I am looking at a 4" Trailmaster or the 6"BDS or Skyjacker kits right now.
  9. tjayandlisa
    tjayandlisa Registered Member
    Feb 14, 2002
    48
    Sacto CA
    4 wheel parts owns procomp as well as alot of other manufacturers...and they are buying more and more as they can...
  10. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    I have decided to ditch my 3.5 inch blocks and go with 4 inch blocks. Then Im going to crank my torsion bar a tad to try to get 4.5 - 5 inches depending on what it looks like once its finished. Still small lift but hey every little bit counts /forums/images/icons/ooo.gif
  11. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    just go for a shackle flip in the rear. my pinion angle is great on my truck. there's no driveline vibes either /forums/images/icons/cool.gif
    i did the homemade flip, where you cut out the bottom of the spring hanger and drop the shackle through. I Reinforced the hanger by fabbing up an "S" shaped metal strap....I welded it to the hanger on the top end,...and i had a hole drilled on the opposite end so i could bolt it on the shackle bolt.
  12. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Since Im so new at the suspension thing I dont think I would be smart enough to figure that out lol I cant weld to save my life eather. /forums/images/icons/smirk.gif
  13. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    There are also shackle flip kits, which is a special bracket that is bolted in place of the stock hanger. I think the hard part is drilling/cutting off the old fastners.
  14. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    yeah, like scotty1 said, you can get the shackle flip kit from ORD. just grind/drill out the told rivets, then bolt the new shackle hanger on.
  15. ChevyHuny
    Aug 17, 2001
    2,279
    Washington State
    Thanks everyone, I already have my blocks but I will check out the shackle flip anyway. /forums/images/icons/smile.gif
  16. scotty1
    Jan 7, 2002
    166
    WV, Harpers Ferry
    the advantage of the shackle flip is the use of the stock springs, which have more flex, and you will avoid/limit any axle wrap problems associated with the lift blocks. I think the bracket runs about $100.
  17. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    the brackets are about $160 from ORD /forums/images/icons/grin.gif
  18. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    If you plan on towing with this truck I would not do a shackle flip.
  19. 1tonblazer93
    1tonblazer93 Registered Member
    Jul 16, 2002
    26
    cali vallejo
    the 3.5 are perfect for you mall cruisers,,keep that 10blt slick
  20. ntaj*ep
    Feb 4, 2002
    3,248
    Evergreen state
    Mall Wha? You got something to say? Say it or get the phuck OUT! /forums/images/icons/confused.gif
    If you want to show up at my door step be my guest! I'll leave the door open for ya just walk right in. /forums/images/icons/mad.gif I'll be there to greet ya.
