IFS Part #s
Discussion in 'The Garage' started by Afireinside, Jan 29, 2005.
  1. Afireinside
    Afireinside Registered Member
    Jan 22, 2005
    61
    Aurora Colorado
    Anyone know the part number for the front axle thermal acuator.I found one at the dealer but i'm trying to spend less than a hundred bucks.I figure some parts store's should have them but know one can find it.Thanks BTW anyone know the tbi gasket(454)part #.thanks.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The only aftermarket one that I know of is sold by Warn. And it costs about the same. :( The newer actuators from GM are actually a little electric motor. It works much better than the earlier heated-gas versions. If you're converting, then you'll also need a short harness adapter. :mad:
  3. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    You can also get a posi 4x4 , which is an in cab, cable actuator. not sure of the cost, but at least it always work.
  4. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    posi lock about the same price. thats what i would get if it was mine!!!!
  5. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    DO NOT PUT ANOTHER THERMAL SWITCH IN!!!
    It was a bad design when they did it and it will leave you stranded at the worst possible time.
    The electro-mechanical replacement is pretty good choice but the cable actuated positive locking setup is the best.
    Sorry ... don't have any part numbers ... I'll look around.
