IFS REMOVAL
Discussion in '1992-Present Chevy & GMC models' started by steve_97, Feb 27, 2002.
  1. steve_97
    steve_97 Registered Member
    Feb 27, 2002
    25
    Boise, Idaho
    I need to find out about what pitman arm to use when doing a straight axle conversion, Im planning on using large chevy tierod ends in the drag link, Just need to know what pitman arm to use and where to get it.
    NEW ADDED...........ORD says that all is needed is to match the pitman arm length to the steering arm, indexing on the ptiman arm may not match but the box has the same splines as older boxes.
    Thanx, Steve
    '73 Blazer 454,465,205,dana 60, 14 bolt, 5.13's and 38's
    '94 chevy ext cab 3/4 ton 4x4 soon to be straight axle w/39's
    &lt;P ID="edit"&gt;&lt;FONT class="small"&gt;&lt;EM&gt;Edited by steve_97 on 03/01/02 05:48 PM.&lt;/EM&gt;&lt;/FONT&gt;&lt;/P&gt;<P ID="edit"><FONT class="small">Edited by steve_97 on 03/02/02 04:03 PM.</FONT></P>
  2. 95GMCD6014
    95GMCD6014 Registered Member
    Feb 21, 2002
    5
    Salinas,CA
    try ORU. ive heard skyjacker makes one that will fit but not for sure.
    95 with no IFS
  3. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    you might wanna check with ORD, they can prolly fix youup for way cheaper than ORU &lt;--- they're really proud of their stufff!! [​IMG]
    <font color=blue>Shorts</font color=blue>
    '94 K1500
  4. tonto
    tonto Registered Member
    Feb 12, 2002
    50
    oklahoma
    look at a pitman arm from a newer model dodge truck. it is 5.5" center on center. got that on from the two part article in fourwheeler about 4 years ago. they published the basics on how someone made their own solid axle conversion. hope it helps. still have the article.
  5. mudddog91
    mudddog91 1/2 ton status
    Dec 28, 2000
    471
    north carolina
    Hey just curious ,i just started my sloid axle swap today and was wondering if you had any pics of yours and any advice would be really helpful!!!!!!!!!!
