IFS rims fit ok on solid axle?
Discussion in 'The Garage' started by Ned Kelly, Apr 21, 2007.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    Just wondering if the IFS plain jane OEM stamped steelies fit ok on solid axle trucks? I'd be interested also if this applies to both 6 bolt and 8 bolt pattern rims. I have a chance for a good deal on Q78-16 tires on IFS factory steelies - wondering if it will be no problem to run them as is on a older solid axle truck.
  2. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    Ihad a set off a 02 chevy, they were steelies, the center hole wasn't big enough to go aroung the hub, and when I grond the hole out, the backspacing was incorrect, it would hit the tie rod. This was just for rolling purposes only, on a non running truck.
    EDIT- They were the 6 lug
  3. dyeager535
    26,975
    My dad's running IFS 8 lugs on his truck, no problems, except you can't make the IFS caps fit, since the hub is in the way. :)
    Edit: these were probably 80's or 90's IFS ones, no idea if anything changed later.
    The 6 lug ones are pretty darn narrow as I recall though, like 6 or 7".
  4. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    I put a set of stock aluminium rims off my brothers 04' 2500 HD on my 74 3/4 ton K20 and they fit very nicely.........
  5. Corey 78K5
    13,055
    Humboldt County, CA
    Oh and it was fulltime hubs FWIW......
  6. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    8 lug stuff will fit, but the 6 lug won't, inless you hog out the hub hole.
  7. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    The 8-lug is a 'neutral' offset much like the older style.
    The 6-lug comes in both a neutral offset (2wd) or a positive offset (4x4). The center holes do need to be enlarged to fit older trucks. The 4x4 one has ~5" backspacing so that one you may have clearance issues with.
  8. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I want to try the 8 lug on a Dana 60 straight axle with the Q78-16's.
  9. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I had the stockers off my 97 on my 89, stock 16x6 with 235s. They fit OK, but since they are hubcentric, they need some persuasion to get them off, read: kick 'em off. Don't forget the lockouts will stick out pretty dang far....
