ifs to solid axel conversion.
Discussion in 'The Garage' started by 69K5, May 20, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i know its been run over 100 times, but i want to look at it again. i did a search and found a little info, but not much. has anyone actually done this? i saw off road unlimiteds page. it looks awful pricey to me. 97 1/2 ton tahoe btw.
    i think that you just need to weld up some hangers. which i what they did, and added reinforcement on the back one.
    if i kept the stock transfer i would need a ford front end. then my bolt pattern is different. any ideas other than swapping it up to 8 lug? i can get a ford front end easy enough.
    if i swap it to a 205 which i have a spare of. i have to find a convereter/adapter and figure out the speedo.
    qnyone know the frame spec differences between the 97 tahoe and say an 88 blazer truck/
    this is for my wife by the way so she isnt gonna need lockers and such. and thanks to everyuone whos brain i already picked on this
    let the pros and cons begin.
    thanks
    nathan
    69K5
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    I did it to my truck using the ORU kit. It's worth it in my opinion instead of sitting down and making sure all the dimensions are perfect, square, etc...
    You really want to look at a 78-79 ford front axle since it's the 8 on 6.5" gm pattern and the 32.5" spring pad width. The newer years have the 36" spring pad width and theres major problems with the tires rubbing on the springs at full lock.
    Anyway, your planning on upgrading the rear too right? That 10 bolt won't hold up long... Best bet is a 14FF to match the 8 lug front.
    My Swap
  3. ZonkRat
    ZonkRat 1/2 ton status
    Jan 16, 2003
    1,003
    Lawrence County Tennessee
    I did my own swap and like said you have to be sure to keep everything square.I spent about 2 weeks doing the swap and have been happy with it so far.If you don't need the 60's beef look for a 3/4 ton Ford D44{78-80?} /forums/images/graemlins/thumb.gif.It's still a HiPin and the pad width is 32in.Some of them use the same dual piston calipers and rotors as the 60.Then find a 8lug 14SF for the rear,it'll be a straight swap for the 10B.
