IFS Upper Ball Joint Removal
Discussion in 'The Garage' started by 92K1500Blazer, Dec 21, 2003.
  1. 92K1500Blazer
    92K1500Blazer Registered Member
    Dec 16, 2002
    7
    Anyone have any tips for removing the upper ball joint on a 92 K1500 IFS? I got the press from autozone, but that thing is so big, it won't fit under the knuckle without removing the axle. Should I go through the trouble of removing the axle, or is there another trick I'm missing?
    Thanks!
  2. jackedjimmy
    jackedjimmy 1/2 ton status
    May 18, 2002
    195
    Redmond WA
    The upper ball joints aren't pressed in. They are rivited in. You need to burn/chisle the old rivets out and the new ones will be bolted in with the supplied bolts. /forums/images/graemlins/thumb.gif
  3. 92K1500Blazer
    Dec 16, 2002
    7
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Trouble of removing the axle? If you've got the ball joint seperated already, you could have removed it in the time it took you to make that post.
  5. jackedjimmy
    May 18, 2002
    195
    Redmond WA
    YA..my bad......BFH time
  6. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    got a pickle fork and a hammer?
  7. 92K1500Blazer
    Dec 16, 2002
    7
    hmmm, yeah, well BFH time is where the last couple of hours went.
    Thanks for the help folks! I think a pickle fork will do the trick
  8. 89K1500Chevy
    89K1500Chevy 1/2 ton status
    Nov 9, 2002
    645
    Georgia, Fayetteville
    It did it for me a pickel fork and hammer are great for this stuff. I dont know why the old ball joints were riveted in with out any nipples for you to regrease the balljoints with? why did they do that /forums/images/graemlins/confused.gif but i have all new stuff now anyways i just need new wheel bearings and i think i have to get all new hubs just to get those... /forums/images/graemlins/angryfire.gif
