Ignition advance system not working
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by weisel, Feb 15, 2002.
  1. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    My HEI system has a snag in it. The little weights that throw out from spinning around at a certin speed, and make the spark advance by rotating that little peice of stee. Well, that little peice of steel is stuck to the rest of the distributor, so it dosn't turn a little and advance the timming. My questions are: How far is it meant to move? How many degrees is it meant to advance the timing? How bad does it hurt the performance? And should I set the timming a little more advanced to compensate?
    No, thats not a dent in my truck's body. I call it my truck's armor.
  2. weisel
    Feb 22, 2001
    491
    Laveen, AZ
    ttt
  3. mdm365
    mdm365 1/2 ton status
    Jul 2, 2001
    536
    mineral wells wv
    the advance will only move as far as the hole the pins go through(the pin the spring hooks to)I have had ran in to this befor and wd40 worked a few times and I also had to pull the dist all a part to free it up if you use wd40 let it sit and work it back and forth. hope this helps. mike m <a target="_blank" href=http://mikes77k5blazer.rockcrawler.com>my k5</a>
    1977 k5-blazer4"pro comp lift 3.5 in rear dana 44,12 bolt rear, 350 &amp;,205 t-case,465 trans,flotech headers and mufflers<P ID="edit"><FONT class="small">Edited by mdm365 on 02/17/02 04:07 PM.</FONT></P>
