Ignition Catastrophe! Desperate!
Discussion in 'The Garage' started by jacob_coulter, Oct 29, 2005.
  1. jacob_coulter
    jacob_coulter Registered Member
    Jun 28, 2005
    12
    USA
    Here is the issue, out of nowhere, the truck that once started up and ran great, is suddenly completely dead. Stopped at a gas station, filled up the tank, turned the key, and nothing, not even a click or grind. It had no issues previously, would always start right up.
    Also, when you turn the key, it doesn't "kick back" in from the starting position, it just sort of freewheels. I am guessing it's the ignition switch, but I am a newbie and unsure. The headlights and accessories work fine. The battery cables have been checked for corrosion/tightness.
    The truck is a '78, with a 400/TH400. Can someone walk me through how to take the steering wheel off and figure this out?
    Thanks again!
  2. gauder
    gauder Banned
    Aug 26, 2005
    1,613
    done
  3. big94gmc
    big94gmc 1/2 ton status
    Sep 1, 2004
    3,651
    No VA.
    If you need a new key cylinder, I can give you the outta my '73 (with key). If not, post up what the problem is, and we'll see what we can do for ya.
