Ignition Catastrophe (Update)
Discussion in 'The Garage' started by jacob_coulter, Nov 5, 2005.
  1. jacob_coulter
    jacob_coulter Registered Member
    Jun 28, 2005
    12
    USA
    Okay, I replaced the ignition switch on the column, put the rod in the proper hole and mounted the switch, and the car started right up, and the key "kicked back" like it's supposed to. I thought I was home free.
    But now, the car wont turn off. The key just freewheels again, this time with the car running. I dropped the column and pulled the ignition rod back (towards the driver) with a pair of pliers to shut it off. It's like the key is a one way switch, I can get the car started, but when I turn the key back, it keeps running. It's almost as if the switch's tension is too much, and the rod breaks free from the key cylinder. I have to manually pull the rod back with the pliers to turn the car off, then I can start it again.
    Any help would be greatly appreciated.
    Thanks again,
    Jacob
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    767
    Granbury, TX
    may want to look at the ignition rack and see if anything is broken in there
  3. jacob_coulter
    Jun 28, 2005
    12
    USA
    Is the ignition rack within the steering column, behind the turn signal switch?
  4. DFR
    DFR Registered Member
    Nov 2, 2005
    9
    Tennessee
    behind the key cylinder you will see where it turns a rod with teeth on them, this is where the rod would run to, sounds like the rode has come off, or spring for return has come loose.
