Ignition Coil Location
Discussion in 'The Garage' started by pomai, Mar 12, 2006.
  1. pomai
    pomai 1/2 ton status Premium Member
    Jan 26, 2002
    435
    3
    Oahu, Hawaii
    Because of the braided steel pressure & return fuel lines and pressure gauge I installed for my TBI. I am unable to put back the coil in the stock location.
    Can I mount it on its side on the fire wall.
    Does it matter what position its mounted in, side ways or upside down.
    Thanks, Ed
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    no it wouldnt matter, but if you mount it too far away from the distributor then youll need a longer secondary wire between the distr and coil of course, and also have to watch length of wires out of the engine harness for the coil
    might have to lengthen them also
    but it wouldnt matter what position the coil was in
    good luck
