Ignition cylinder replacement
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by anatomiczero, Jan 16, 2003.
  1. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
  2. dyeager535
    26,979
    If I were you I'd call a local lock shop. They'll be able to tell you exactly how much one is for your vehicle, and that it will fit. That one looks correct, but they had at least two different cylinders fopr the trucks, probably more. (based on year)
    You can follow the tilt column tightening procedure to get down to the lock cylinder, it's an easy swap.
    Is your key worn down? Worn keys but a good lock cylinder can cause problems too. If you can, you might take it down to the lock shop so that they can verify it's shot.
  3. StoneyK5
    StoneyK5 1/2 ton status
    Jan 4, 2001
    472
    Birch Bay, Wa.
    I agree with Dorian. Go to a lockshop and get the key checked first and if it's just a key needed it'll only cost about 6 bux. They probably charge about 12 bux for a new ignition cylinder if one is needed, same as the ebay price. Not sure if yours has a screw retainer, as the one on ebay, or if you just have a spring clip retainer, but the lockshop will know.
