ignition module help please
Discussion in 'The Garage' started by k5moneypit, Jan 23, 2004.
  1. k5moneypit
    k5moneypit Registered Member
    Jan 6, 2004
    18
    brownstown,michigan
    yep gone through my upteenth ignition module, module company says alternator back feed, but also looking for anybody with the same problem.Thank god for lifetime warrantys /forums/images/graemlins/1zhelp.gif87 k5 tbi 350
  2. dyeager535
    26,982
    191
    If search was working, I'd say use it, because I'm SURE I saw that someone had the exact same issue you are having. /forums/images/graemlins/frown.gif
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Bout the only thing I can think of is to Install a diode between the alt and the ign. I have never done this but I heard it works for your problem. I think some parts companys make them that plug right in the wireing.
    ****EDIT****
    I did a search and came up with this.
    http://www.americanautowire.com/new-stuff.htm
  4. k5moneypit
    Jan 6, 2004
    18
    brownstown,michigan
    thanks thunder appreciate that. That is also what the ignition module company told me to.I shall try this. Thanks again for the search info. /forums/images/graemlins/thumb.gif /forums/images/graemlins/k5.gif
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Check with a local electronics store. A 5 or 10 amp diode (which is what the one in the pic looks like to me) should only cost $1 or so. /forums/images/graemlins/thumb.gif
  6. k5moneypit
    Jan 6, 2004
    18
    brownstown,michigan
    yeah i called painless and they said a 6 amp 10 watt diode in the ignition hot lead should do the trick. Thnks guys
