ignition module malfunctioning?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87project, Jul 27, 2002.
  1. 87project
    87project Registered Member
    Jul 9, 2002
    98
    Alabama
    if the ignition module was malfunctioning would a sympton be going dead while driving or putting it in gear after it warms up? (alot worse on hot,humid days)any input would be greatly appreciated. 87 Jimmy 5.0 TBI
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    modules will act like that when they are going bad.. Most auto parts stores like Napa, Autozone, Checker, ect.Will test them for you if you pull it out and take it down to them.
  3. kchecca
    kchecca Registered Member
    Sep 26, 2001
    36
    Feeding Hills, MA
    Yeah, sounds familiar. Just did mine about a month ago. Acted like the fuel pump was dead. Stumbled in gear a bit and real rough idle, then finally just died and wouldnt start at all. $40 at Napa and 15 minutes, once I knew that the module was the problem.
  4. Haulgas
    Haulgas 1/2 ton status
    Mar 25, 2001
    208
    Phoenix Az
    I had the same problem on my 87 but it was the water temp sensor by the thermostat. Just my 2 cents..... /forums/images/icons/grin.gif
