Ignition Module
Discussion in 'The Garage' started by Blazer1AB, Sep 2, 2005.
  1. Blazer1AB
    Blazer1AB Registered Member
    Sep 1, 2005
    29
    KC
    Where is it located on an 83 K5? A pic or diagram would be helpful.
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    It is inside the distributor . It is under the rotor , bolted on with a couple 1/4 inch machine screws course thread . It is easily removed and replaced with hand tools .
    It is almost like any other HEI distributor , except if original it has an extra plug ( weatherpack connector ) for the spark computer under the dash .
    I replaced mine with a 70's HEI distributor .
  3. gimmie11s
    gimmie11s Registered Member
    Jun 19, 2005
    13
    so cal
    please explain why.
    i believe im having problems with my Dist. on an 85 K5.
  4. Blazer1AB
    Sep 1, 2005
    29
    KC
    So if the distributor was replaced then the ignition module was also replaced??
  5. dyeager535
    26,979
    Yes. Replaced however, does not mean good.
    Aftermarket ignition stuff is bad about not working, straight out of the box.
