Ignition pick-up coil question
Discussion in 'The Garage' started by opfor2, Sep 25, 2005.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    How do I replace the ignition pick up coil on a 1990 HEI distribitor? I have the new coil but can't figuer out how to get the old one off.
    Dan..
  2. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    you have to drill out the rivets. I ended up replacing my whole dist. couse the magnitos were non magnitized :doah: .
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    You need to remove the distributor from the engine, drive out the gear pin, remove the gear and pull the rotor shaft out the top, then the pick-up coil ust unscrews, or in some cases it's held in with riviet, as the previous person said, just drill them out.
