Ignition Problems, Please Help!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Wraparound, Nov 6, 2002.
  1. Wraparound
    Wraparound Registered Member
    Feb 23, 2000
    91
    Sacramento
    Can anyone tell me why I would have spark between my coil and my cap and nothing at the spark plug? I've replaced the cap and rotor several times and I keep having the same problem within a few weeks. Thanks
    87 GMC TBI
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Did you rotate or take the distributor out?
  3. Wraparound
    Feb 23, 2000
    91
    Sacramento
    No, Wondering if the coil is to week to jump with a little buildup.
  4. weisel
    weisel 1/2 ton status
    Feb 22, 2001
    491
    Laveen, AZ
    How can you tell if you have spark between the coil and cap?
    Seems to me that you wouldn't be able to see if it is sparking
    or not.
  5. Wraparound
    Feb 23, 2000
    91
    Sacramento
    I put a spark plug in the coil wire. The coil is not in the cap on this distributer.
  6. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Does it work right off the bat if you change the cap and rotor? What do the old caps/rotors look like? Sounds like your getting moisture in there or something. How many ohms resistance are your wires giving?
