Ignition switch removal
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by Rusty68, Mar 25, 2003.
  1. Rusty68
    Rusty68 1/2 ton status
    Jan 22, 2003
    116
    Elko, Nevada
    Lucky me, I lost my keys. How in the heck am I going to get my ignition switch out to replace it? I bought one and it is hanging by the wires under the dash for now. I tried pushing in that little button, but I guess you have to have a key to turn the lock back. HELP!!
  2. BluThndr71JMMY
    BluThndr71JMMY 1/2 ton status
    May 12, 2000
    152
    Tucson, AZ
    There are only 2 options:1) Locksmith2) Big drill.
  3. 1 FN HI K5
    1 FN HI K5 1/2 ton status
    Aug 7, 2001
    465
    Northern CA Out in the stick\'s
    [/ QUOTE ] Yep you's screwed with out the key you will have to drill it out... <font color="red"> 1 FN HI K5 </font>
  4. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    The trim ring around the ignition switch is a nut. I used a snap ring plier to grip the notches on the thing and remove it. If you're a neanderthal you can use a screwdriver and hammer and buy a new nut.
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I tried to unscrew the ring as much as I could and finished it off with a hammer and punch. I'm glad I bought a new trim ring as well as the tumbler.
  6. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    hammer and punch is what to do after unscrewing the bezel a bit, the threads on the bezel wil be ruined though and youll need to find another one
    good luck
  7. Rusty68
    Jan 22, 2003
    116
    Elko, Nevada
    Hmm, I am in the process of trying to thread the ring off, but it seems to have stripped and no longer backing off. Do I need to drill out the center lock portion? Or the whole body?
  8. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    As others have said, just knock it out with a hammer and punch now. I did this on a parts truck that I didn't have the key for. You will need a new bezel.
  9. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    they wont come off til you remove the lock cylinder in which you need key to do, the ring has a groove that stays under the cylinder assembly, you are screwed if you dont punch out the lock, one good whack with punch will do it
