Ignition switch, were you put the key in....broke
Discussion in 'The Garage' started by TexasBlazerBoy, Apr 4, 2007.
  1. TexasBlazerBoy
    TexasBlazerBoy 1/2 ton status
    Oct 10, 2005
    1,674
    North Texas
    I broke the key-ignition-switch mounted on the steering colum.
    Questions:
    Do I need to remove the steering wheel to fix this?
    Has anyone done this?
    Do you have any tips?
    Thanks in adavnce for the input.
    Larry
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Yep, remove steering wheel, lockplate, turn signal cam (just unscrew it and move out of the way, then remove the screw that holds in the key tumbler and remove. Pretty simple.
  3. chalet2506
    chalet2506 1/2 ton status Premium Member
    May 9, 2006
    4,931
    Skeddadlin
    Get you a steering wheel puller. Also, don't do it late a night with a 12 pack and decide you need to disconnect a bunch of wires with a screwdriver and a hammer down at the bottom of the steering column.:whistle:
    One more thing, don't get the cheap tumbler from O'reily's, it's got the wrong amount of teeth on it and your key positions will be off. You need to get you a manual if you don't already have one. I think mine's a Haines and its usually got pretty good step by steps in it
  4. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Steering wheel puller-check
    Get 12 pack- check
    Hammer-check
    screwdrvier-check
    I think I have the Chiltons, I didn't even think to look in it.
    Ya, O'reilly's has a cheap one, and they have the AC Delco part also, I will go with the AC Delco.
  5. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah i broke mine too. ended up doing a bunch of wiring instead of fixing the real problem. now i've got an ignition in my cig lighter, fuel cutoff switch, and a separate key for unlocking my steering wheel!
    fwiw, if you need to drive, you can start/stop your engine by getting the whitish switch off the top of the steering column (behind the triangle shaped deal behind the dash). to get to this, drop the steering wheel down a bit by removing the collar that holds it to the dash. then you can make due w/ a screw driver by pushing the lever back and forth in the switch.
  6. TexasBlazerBoy
    Oct 10, 2005
    1,674
    North Texas
    Thanks Colby.
    A friend of mine showed me that little trick. Good stuff.
