ignition systems ?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by kool, Feb 8, 2002.
  1. kool
    kool Registered Member
    Feb 6, 2002
    9
    Seattle, Wash
    My 89' K1500 has basically the stock 350, with the exception of a chip, power pulleys, and a drop-in K&N. I'd like to up-grade the ignition system . Not sure if I want an MSD, Jacobs, etc... Also should I go with a box type system or just a coil and module? I also have plans on getting headers and getting a Holley TBI system if that makes any difference. AAHH hell , what are a good choice of headers for these trucks? Thanx for the info..
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Heres what I have on my 89K5 for engine up grades.
    Edelbrock Headers( TES).... I like them it was an esay bolt, on and they work good. still look new after 2 years no rust.
    3" single exhaust with Flowmaster 3" 70 series mufler..... works good, not real noisy
    6-a MSD Ign box and blaster coil.
    Modified stock TBI, K&N + I modified the stock breather Tube and box so I get better flow and cool air.
    I have heard of quite a few problems with the Jackobs ign stuff and the Holley TBIs.
    For the iginition box. MSD is good but if you get a 6-a box mount it somewhere or cover it so it wont get wet.( I mounted mine in the cab) The off road box and the 6-T boxes are water proof but cost more.
    Mallory also just came out with a digital box called the HI- FYRE VI for 120.00 I have heard works real well. Its on my "stuff I gotta get list". Summit sells them.
    Instead of the holley TBI you might want to look in to some of this stuff from<a target="_blank" href=http://www.turbocity.com/TBIPowerMain.htm> Turbocity.com</a>.
    I'm using a lot of the equipment on that page(air flow enhancer,Injector spacers, matched injectors, ect) and am very satisfied with the results. I havent decided if I like the "Fuel Enhancer selector" yet. But it does help give better fuel milage.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  3. high&liftedup
    high&liftedup Registered Member
    Nov 14, 2001
    64
    CA
    My Experience: I had major problems with accel. I changed over to the MSD HEI Billet Dist/Off road box. The billet dist. gives you options on changing spring tension for your mechanical advance. Get a set of stock plugs with .055-.060 gap.and MSD 8mm wires. Also, MSD reps have been a great support during my 'trials' with the accel.
    I have only read info on Jacobs. If you check out alot of the race cars/trucks/dragsters, I would say 90-95% use MSD.
    Headers: I really am not satisfied with the headman headers I have. I did have the flanges re-welded and surfaced, but I couldn't use 4 of the stage 8 bolts because of the close tolerances. They also discolored fast even after sandblast/repaint.. and.. still some leakage.
    HE will always get you out of the mire clay!!!
  4. dyeager535
    26,979
    You know there really isn't much point to upgrade, right?
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Get an MSD 6 series box, MSD coil, and MSD super conductor wires. I have them and I love them. They are great. They helped out my 350 alot. Throttle response, gas mileage, and power all picked up after the box was installed.
    My Chevy isn't broken, its just out of gas.
