ignition timing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BUSCO, Jan 1, 2002.
  1. BUSCO
    BUSCO Registered Member
    Mar 4, 2001
    38
    New York(11552)
    I believed that proper ignition timing was zero degrees on an '87 5.7 tbi,is this correct or not?Also I am using an MSD 6a ignition box should I open up the gap on the spark plugs a little?Thanks for any help.......
    PS> I stripped and repainted the upper radiator support so I don't have the emmisions sticker any more.OOPS
    <P ID="edit"><FONT class="small">Edited by BUSCO on 01/01/02 02:25 PM.</FONT></P>
  2. 4x4k20
    4x4k20 1/2 ton status
    Mar 17, 2001
    1,699
    williamson ga.30292
    0 degrees is rite just be sure to disconnect the timing connector i also would add about 10 thousandnt to your plugs
    4x4k20
