ignition tumbler ?
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by GMMANIAC, Mar 6, 2003.
  1. GMMANIAC
    GMMANIAC Registered Member
    May 1, 2002
    53
    San Antonio, Tx.
    I'm working on a buddy's '71 Jimmy and the ignition tumbler locked up. I know the lock needs to be in a certain position before the button inside the switch can be pushed. With a little effort I can turn the key, just need some info on where the hole should be. Any help would be great. /forums/images/graemlins/confused.gif
  2. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    need to have the key in the accessory position(left)
  3. GMMANIAC
    May 1, 2002
    53
    San Antonio, Tx.
    Thanx for the info. I'll go give it a try.
  4. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    go all the way to the left then put in paper clip or other into hole.if it wont go back into the acc position then replace the holw asylmbly for 14 bucks like i did.
