Ignition upgrade
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stickshooter, Feb 12, 2002.
  1. stickshooter
    stickshooter Registered Member
    Oct 26, 2001
    23
    Who makes an idiot proof electronic ignition kit that I can put on my '81 K5. I have a 305 now but intend to put a 350 in within the next couple of months.
  2. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    You can use all the stuff out of your 305.
    Or if you want to upgrade get a DUI Blazer pics
    <font color=blue>Nevada... Where the pavement ends and the west begins
  3. dyeager535
    26,979
    nothing wrong with stock HEI
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>www.dorianyeager.com/index2.html</a>
    Why insist on counting when the ring gear has the tooth counts stamped in?
  4. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I agree with Dorian... nothing wrong with HEI unless you plan for over 4500 rpm. I run an MSD offrad ignition that works well, but I would recomend getting a MSD coil, new hi-performance MSD or Taylor wires, and new plugs gapped at .055 or .060
    The DUI distributor is also a nice item with good wires and plugs
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    MSD all the way. Thats what I have on my 85 and I love it. Just use the set up CaptCrunch described (same thing I have) and it will pep your rig up.
    My Chevy isn't broken, its just out of gas.
  6. kool
    kool Registered Member
    Feb 6, 2002
    9
    Seattle, Wash
    I've used the stock HEI and replaced the module with an MSD module and put in the MSD coil. It's a cheap up-grade ($100.00 or less) and works like a champ.
  7. stickshooter
    Oct 26, 2001
    23
    Thanks, that's all I needed to hear.
