Ignition Wiring...need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazer89, Nov 23, 2000.
  1. blazer89
    blazer89 Newbie
    Nov 23, 2000
    NJ
    Here's the deal.... I bought this remote starter kit and i pulled the panel under the steering colum off and i cant seem to find the correct wires..I need to know what colored wire/ and where exactly i can loacte them for my 1989 k5 blazer. THESE ARE WHAT I NEED TO FIND
    1)the wire which ONLY reads 12v. when starter is cranking...
    2)the wire the read 12v. ONLY when "accessory" in on....
    3)the wire is 12v when on accessory AND run..
    4)and lastly which wire is 12v. ONLY when key is in run position....
    THANKS in advance
  2. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    Re: Ignition Wiring
    1) This one may be hard to find. I'll look in a wire diagram and send you a private if I find it
    2) Your fuse box should have an "acc" place to plug into(like your radio is pluged into)
    3) I think?!?!?!it would be the same as the above wire????
    4) I don't know- My neighbor installs sterios and alarms. After I get back from the holidays, I'll ask him
    Don't know if I helped, but I tried!!!
    blazen91
    Protect the land FOR the people
    <font color=red>Not FROM the people</font color=red>
